    • На форуме с 22 06 2009, 10:36
    • Сообщений 10
пендосы пишут:
Цитата:
GL-4 and GL-5 are standards set by the American Petroleum Institute for gear oils. GL-4 are intended for axles with spiral bevel and hypoid gears operating under moderate to severe conditions of speeds and loads. They are also suitable for sychronized manual transmissions when MT-1 gear oils are NOT recommended. GL-4 should be used in limited-slip differentials. The GL-4 generally indicates "Limited Slip" properties in the gear oil; sometimes abbreviated as LS.
GL-5 is indicated for high-speed/shock loads and low-speed/high-torque conditions. GL-5 also has multi-purpose or mild EP (extreme) properties too. GL-5 is often seen with the MT-1 designation too.
MT-1 indicates lubricants intended for NON-sychronized manual transmissions. MT-1 indicates the additional additives necessary to protect against thermal degradation, component wear and oil-seal deterioration which are not requirements by GL-4 or GL-5 approval.
GL-5 is not the latest and greatest improvement over GL-4 ::nenado:: ; unlike oil classifications where higher classification numbers mean tougher standards and backward compatiblity. It is important to know what type of gears you are lubricating, their applications and follow the manufacturer's recommendations.
What are the manufacturer's (BMW) recommendations for this type of gear ? и что про это написано в "о великом" тисе ??
E46 седан 320i M52 ручка
    • На форуме с 15 01 2011, 21:42
    • Сообщений 596
    • Авто: Были:е 36 compact,М 43,МКПП и е 30 coupe,М 10,МКПП.Сейчас :е 46(4),320,М 52,МКПП
Доброго времени суток!
...Плохо включалась 1-ая передача,проверил уровень масла....оказалось ниже нормы и сильно загажено.
Решил поменять,в магазине посоветовали Motul Gear 300 75W-90 (700р.литр),сказали что оно и в редуктор льется.
У кого-нибудь был опыт по эксплуатации оной жижи???
Или лучше какое то другое?
325 тыс.км,мкпп,vin ca06447
...дождя хватит на всех....
    • Сообщений 3123
    • Авто: e46 320i '99
Если оригинал дорого, то заливайте Pentosin MTF2, уж в Москве то точно с этим нет проблем.
    • Сообщений 1833
    • Авто: 320D TURING M47TU
    • Изображения: 65
Gudok писал(а):
Какое масло должно быть залито в редуктор 320i e46 M52 мкпп, а то устал спорить с продавцами.
Castrol Syntrax Long Life 75W-90(старое название SAF-XO 75W-90 )
http://www.castrol.com.ru/castrol/syntrax_long_90.php
[pic]43777[/pic]
    • На форуме с 11 12 2010, 21:25
    • Сообщений 71
    • Авто: BMW 325Ci
Подскажите кто какое масло мне лить в мкпп лазил лазил на коробке нифига ненашол ::39:: , и скока его туда нужно, 325Ci 2001г. Спасибо :???:
    • Сообщений 1833
    • Изображения: 65
Castrol Syntrans B 75W
http://www.castrol.com.ru/castrol/syntrax_b.php
два литра брать нужно , чуть останется
[pic]43777[/pic]
    • На форуме с 21 11 2010, 12:39
    • Сообщений 6383
    • Авто: Е46 M3///
1100мл
Рекомендуем почитать на тему Трансмиссионные масла
    • На форуме с 02 09 2011, 13:22
    • Сообщений 113
    • Авто: BMW 318Ci
Доброго дня.
Подскажите какое масло идет в АКПП E46 N46B20 2004г.в. пробег 149 000
Вин - ew78497
А то подошло время менять(как оказалось пробег скручен,вследствие чего и было решено поменять на всякий случай).
Заранее спасибо.
    • Сообщений 3778
    • Авто: solaris
    • Изображения: 15
ArtemW писал(а):
Доброго дня.
Вин - ew78497
Заранее спасибо.
кнопка поиск
viewtopic.php?f=17&t=63885
    • На форуме с 22 05 2011, 14:16
    • Сообщений 18
raix55 писал(а):
Хочу уточнить для себя!!!!!!! Масло для АКПП ETL 7045E 83 22 0 403
ЕМУ АНАЛОГ DEXRON VI BMW 83 22 0 397 114 ПЛЮС
заменяет все старые номера
BMW 83 22 0 403 248
BMW 83 22 0 403 249
BMW 83 22 0 432 807
BMW 83 22 9 407 858
BMW 83 22 9 407 859
ТАК!!!!!!!!!!!! ::39::
а вот и нет, для ETL 7045E аналога нет, это Dexron IIIG, у мобила есть тоже Dexron IIIG но по другим спецификациям отличается, я сравнивал наклейки, а менять ETL 7045E (минералка) на Dexron VI (синтетика) можно только на более современной коробке GM6, о чем в твоей ссылке и написано мелким шрифтом, на GM5 вариантов замены нет.
http://tech.bentleypublishers.com/servl ... pacity.pdf
    • Сообщений 5823
Код:
смотри, тут терлось много раз что укатанные коробки после смены масла вообще не арбайтн
Бортовик 318D-->330D
    • На форуме с 31 08 2011, 10:48
    • Сообщений 1642
    • Авто: Хороший
скоко лазил нихрена понять не могу , там такие буквы-цифры , тут такие , будьте добры подскажите в коробку МКПП e46 99 год m52 мотор, пробег 316000 вин wbaam11060jm36548
в редуктор Castrol Syntrax Long Life 75W-90 как я понял
    • Сообщений 1642
    • Авто: Хороший
в выходные менять собрался , кто знает выручите
    • На форуме с 11 11 2011, 12:35
    • Сообщений 280
    • Авто: e39 523i@99 m52tu ркпп + e46 320i"98 m52tu акпп
Господа, моей е46 подходит время инспекшена, большую часть запчастей уже купил/заказал, осталось немного, но самое важное. Можно ли по вин номеру определить конкретную модель коробки (для заказа масла под замену), а так же необходимое масло для редуктора. Какие нибудь фильтра и тп. при смене масла в акпп и редукторе меняются?
WBAAM11040CA25320
    • На форуме с 29 04 2010, 14:07
    • Сообщений 119
http://de.bmwfans.info/parts/catalog/E4 ... nsmission/
вин не дает однозначный ответ...
две коропки на выбор
может офицыалы скажут...
    • На форуме с 26 05 2012, 13:44
    • Сообщений 260
    • Авто: BMW 318i 2.0литра 143л.с
а масло в акпп надо менять ????
    • Сообщений 260
у мня бмв н42в20 2004 года.пробег 117 тыс.меняеться ли в ней масло в акпп?!???
    • Сообщений 260
ауууууу!!!!дайте кто совет!!!!! ::34:: ::34:: ::34::
    • Сообщений 1833
    • Изображения: 65
это как раз тот случай, когда никто не возьмет на себя ответственность давать советы...и не менять плохо и "взбалтывать" осадки плохо ....если бы машина у тебя с новья и ты меняешь каждые 50т не накапливая шлама--это гуд, ...в общем все зависит от истории и видов на длительность дальнейшего пользования автомобилем.....
[pic]43777[/pic]
    • Сообщений 260
ну хоть подскажите есть какой щуп что ли по которому смотрят количество масла???и вообще меняеться оно только при разборке акпп или есть пробки какие то???? :shock:
    • На форуме с 18 12 2009, 15:28
    • Сообщений 870
    • Авто: BMW X5 3.0d 2004
    • Изображения: 17
читаем первую страницу, там есть такая ссылка http://bmw.autocats.ru/parts/ и определяемся с коробкой. Потом читаем здесь viewtopic.php?f=17&t=11920
и понимаем, что менять всё таки надо
лично я заглянул под машину:
и купил необходимое масло
поменял методом замещения и всё ОК!
P.S. просто очень много тем про АКПП и те кто разбираются наверное устали отвечать....
    • Сообщений 260
большушее спасибо за помощь!!!!!
    • На форуме с 07 04 2012, 10:11
    • Сообщений 4478
    • Авто: Ford Transit Bus 18+1 кондиционер
    • Изображения: 36
привет.У меня АКПП A5S325Z.На поддоне никаких наклеек не нашел.Надо поменять масло и фильтр.Что брать я так и не определил.Какое масло залито тоже не знаю.Помогите с выбором,пожалуйста.
Mobilniy писал(а):
У вас декабрь - у нас апрель.
У вас морозы - у нас капель.
У вас разборка - у нас минет.
У вас проблемы - у нас их нет.
Летите, тучки и ветер дуй!
Хотите в гости? А вот вам :???:
    • Сообщений 870
    • Изображения: 17
http://tis.bmwcats.com/doc1048812/
Esso LT 71 141 теперь под Mobil
    • Сообщений 4478
    • Изображения: 36
Спасибо большое.Заправочный объем 9л.?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 85
Яндекс.Метрика cron
