№76
20 10 2011, 15:04
пендосы пишут:
Цитата: GL-4 and GL-5 are standards set by the American Petroleum Institute for gear oils. GL-4 are intended for axles with spiral bevel and hypoid gears operating under moderate to severe conditions of speeds and loads. They are also suitable for sychronized manual transmissions when MT-1 gear oils are NOT recommended. GL-4 should be used in limited-slip differentials. The GL-4 generally indicates "Limited Slip" properties in the gear oil; sometimes abbreviated as LS. GL-5 is indicated for high-speed/shock loads and low-speed/high-torque conditions. GL-5 also has multi-purpose or mild EP (extreme) properties too. GL-5 is often seen with the MT-1 designation too. MT-1 indicates lubricants intended for NON-sychronized manual transmissions. MT-1 indicates the additional additives necessary to protect against thermal degradation, component wear and oil-seal deterioration which are not requirements by GL-4 or GL-5 approval. GL-5 is not the latest and greatest improvement over GL-4 ; unlike oil classifications where higher classification numbers mean tougher standards and backward compatiblity. It is important to know what type of gears you are lubricating, their applications and follow the manufacturer's recommendations.What are the manufacturer's (BMW) recommendations for this type of gear ? и что про это написано в "о великом" тисе ?? |
№77
02 11 2011, 17:18
Доброго времени суток!
...Плохо включалась 1-ая передача,проверил уровень масла....оказалось ниже нормы и сильно загажено. Решил поменять,в магазине посоветовали Motul Gear 300 75W-90 (700р.литр),сказали что оно и в редуктор льется. У кого-нибудь был опыт по эксплуатации оной жижи??? Или лучше какое то другое? 325 тыс.км,мкпп,vin ca06447 |
№78
02 11 2011, 17:30
Если оригинал дорого, то заливайте Pentosin MTF2, уж в Москве то точно с этим нет проблем.
№79
17 11 2011, 19:51
Gudok писал(а): Какое масло должно быть залито в редуктор 320i e46 M52 мкпп, а то устал спорить с продавцами. Castrol Syntrax Long Life 75W-90(старое название SAF-XO 75W-90 ) http://www.castrol.com.ru/castrol/syntrax_long_90.php |
№80
18 11 2011, 14:35
Подскажите кто какое масло мне лить в мкпп лазил лазил на коробке нифига ненашол
, и скока его туда нужно, 325Ci 2001г. Спасибо |
№81
19 11 2011, 21:23
D3nv3r писал(а): Подскажите кто какое масло мне лить в мкпп лазил лазил на коробке нифига ненашол , и скока его туда нужно, 325Ci 2001г. Спасибо Castrol Syntrans B 75W http://www.castrol.com.ru/castrol/syntrax_b.php два литра брать нужно , чуть останется |
№82
19 11 2011, 21:52
D3nv3r писал(а): Подскажите кто какое масло мне лить в мкпп лазил лазил на коробке нифига ненашол , и скока его туда нужно, 325Ci 2001г. Спасибо 1100мл |
Рекомендуем почитать на тему Трансмиссионные масла
№83
15 12 2011, 15:17
Доброго дня.
Подскажите какое масло идет в АКПП E46 N46B20 2004г.в. пробег 149 000 Вин - ew78497 А то подошло время менять(как оказалось пробег скручен,вследствие чего и было решено поменять на всякий случай). Заранее спасибо. |
№84
15 12 2011, 15:51
ArtemW писал(а): Доброго дня. Подскажите какое масло идет в АКПП E46 N46B20 2004г.в. пробег 149 000 Вин - ew78497 А то подошло время менять(как оказалось пробег скручен,вследствие чего и было решено поменять на всякий случай). Заранее спасибо. кнопка поиск viewtopic.php?f=17&t=63885 |
№85
28 12 2011, 17:47
raix55 писал(а): Хочу уточнить для себя!!!!!!! Масло для АКПП ETL 7045E 83 22 0 403 ЕМУ АНАЛОГ DEXRON VI BMW 83 22 0 397 114 ПЛЮС заменяет все старые номера BMW 83 22 0 403 248 BMW 83 22 0 403 249 BMW 83 22 0 432 807 BMW 83 22 9 407 858 BMW 83 22 9 407 859 ТАК!!!!!!!!!!!! ![]() а вот и нет, для ETL 7045E аналога нет, это Dexron IIIG, у мобила есть тоже Dexron IIIG но по другим спецификациям отличается, я сравнивал наклейки, а менять ETL 7045E (минералка) на Dexron VI (синтетика) можно только на более современной коробке GM6, о чем в твоей ссылке и написано мелким шрифтом, на GM5 вариантов замены нет. http://tech.bentleypublishers.com/servl ... pacity.pdf |
№86
09 01 2012, 15:50
Код: (как оказалось пробег скручен,вследствие чего и было решено поменять на всякий случай) смотри, тут терлось много раз что укатанные коробки после смены масла вообще не арбайтн |
№87
15 02 2012, 00:29
скоко лазил нихрена понять не могу , там такие буквы-цифры , тут такие , будьте добры подскажите в коробку МКПП e46 99 год m52 мотор, пробег 316000 вин wbaam11060jm36548
в редуктор Castrol Syntrax Long Life 75W-90 как я понял |
№88
16 02 2012, 07:05
в выходные менять собрался , кто знает выручите
№89
04 03 2012, 15:29
Господа, моей е46 подходит время инспекшена, большую часть запчастей уже купил/заказал, осталось немного, но самое важное. Можно ли по вин номеру определить конкретную модель коробки (для заказа масла под замену), а так же необходимое масло для редуктора. Какие нибудь фильтра и тп. при смене масла в акпп и редукторе меняются?
WBAAM11040CA25320 |
№90
03 04 2012, 13:39
http://de.bmwfans.info/parts/catalog/E4 ... nsmission/
вин не дает однозначный ответ... две коропки на выбор может офицыалы скажут... |
№91
26 05 2012, 19:01
а масло в акпп надо менять ????
№92
26 05 2012, 19:03
у мня бмв н42в20 2004 года.пробег 117 тыс.меняеться ли в ней масло в акпп?!???
№93
31 05 2012, 00:25
ауууууу!!!!дайте кто совет!!!!!
№94
31 05 2012, 20:25
shapa51 писал(а): ауууууу!!!!дайте кто совет!!!!! ![]() это как раз тот случай, когда никто не возьмет на себя ответственность давать советы...и не менять плохо и "взбалтывать" осадки плохо ....если бы машина у тебя с новья и ты меняешь каждые 50т не накапливая шлама--это гуд, ...в общем все зависит от истории и видов на длительность дальнейшего пользования автомобилем..... |
№95
31 05 2012, 20:32
grin1 писал(а): shapa51 писал(а): ауууууу!!!!дайте кто совет!!!!! ![]() это как раз тот случай, когда никто не возьмет на себя ответственность давать советы...и не менять плохо и "взбалтывать" осадки плохо ....если бы машина у тебя с новья и ты меняешь каждые 50т не накапливая шлама--это гуд, ...в общем все зависит от истории и видов на длительность дальнейшего пользования автомобилем..... ну хоть подскажите есть какой щуп что ли по которому смотрят количество масла???и вообще меняеться оно только при разборке акпп или есть пробки какие то???? ![]() |
№96
02 06 2012, 08:58
читаем первую страницу, там есть такая ссылка http://bmw.autocats.ru/parts/ и определяемся с коробкой. Потом читаем здесь viewtopic.php?f=17&t=11920
и понимаем, что менять всё таки надо лично я заглянул под машину: ![]() ![]() и купил необходимое масло ![]() поменял методом замещения и всё ОК! P.S. просто очень много тем про АКПП и те кто разбираются наверное устали отвечать.... |
№97
02 06 2012, 10:50
Илья Северянин писал(а): читаем первую страницу, там есть такая ссылка http://bmw.autocats.ru/parts/ и определяемся с коробкой. Потом читаем здесь viewtopic.php?f=17&t=11920 и понимаем, что менять всё таки надо лично я заглянул под машину: ![]() ![]() и купил необходимое масло ![]() поменял методом замещения и всё ОК! P.S. просто очень много тем про АКПП и те кто разбираются наверное устали отвечать.... большушее спасибо за помощь!!!!! ![]() |
№98
05 06 2012, 23:46
привет.У меня АКПП A5S325Z.На поддоне никаких наклеек не нашел.Надо поменять масло и фильтр.Что брать я так и не определил.Какое масло залито тоже не знаю.Помогите с выбором,пожалуйста.
Mobilniy писал(а): У вас декабрь - у нас апрель.
У вас морозы - у нас капель. У вас разборка - у нас минет. У вас проблемы - у нас их нет. Летите, тучки и ветер дуй! Хотите в гости? А вот вам |
№99
06 06 2012, 08:49
BMW_M_Sport писал(а): привет.У меня АКПП A5S325Z.На поддоне никаких наклеек не нашел.Надо поменять масло и фильтр.Что брать я так и не определил.Какое масло залито тоже не знаю.Помогите с выбором,пожалуйста. http://tis.bmwcats.com/doc1048812/ Esso LT 71 141 теперь под Mobil |
№100
06 06 2012, 14:19
Спасибо большое.Заправочный объем 9л.?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 152 |
