/ Продам блок ULF - Bluetooth - 2500р на BMW
    • На форуме с 21 11 2010, 12:39
    • Сообщений 6383
    • Авто: Е46 M3///
Продам:
Блок ULF (Bluetooth) - арт. 84216938610 - Цена - 2500 руб. торг )
Последний раз редактировалось RostoS 28 06 2017, 23:45, всего редактировалось 2 раз(а).
    • Сообщений 6383
    • Авто: Е46 M3///
чем кстати улф от тцу отличается не вкурсе?
    • На форуме с 12 03 2012, 14:58
    • Сообщений 1135
    • Авто: BMW 320i M54
STR8
The simple answer is that if you just want basic Bluetooth functionality and don't care about Voice Recognition, then you can simply order the TCU. If you care about VR for the phone, then you can program the TCU.
If you care about an eject box / snap-in adapter or VR for Navigation, then the ULF is the way to go.
Comparison:
TCU: (Telematic Control Unit)
- Costs less than the ULF (circa $350 US)
- TCU does not support eject box or pairing button.
- Full Voice Control is not supported out-of-the box. Voice Recognition can be enabled via coding for the phone only, not navigation
- TCU supports BMW Assist (US only, and if your car was equipped with it from factory)
ULF: Universal Ladefreisprechelektronik (Universal Hands-Free System)
- The ULF system for the e46 had 13 generations of revisions to it. Most US dealers only sell the first generation -552 unit. These older units have a ton of issues and won't pair with most modern phones. Anything 6th generation and newer is pretty good. The 6th generation unit will pair with an iPhone 4 for instance. ECS Tuning can special order these to the US, along with Bimmernav.
- The ULF is more expensive than the TCU. Runs about $600-$700 for the ULF.
- Out-of-the box, Voice Control is enabled for both the phone and Navigation if you have it (no coding necessary)
- Visteon is the OEM for BMW of these units
- The ULF requires either a pairing button (OEM ones have been discontinued, but you can make one fairly easily) or an eject box that has a pairing button built into it. The pairing button is only required for initial pairing of the phone. NOTE: The button on the steering wheel is NOT a pairing button, nor can it be wired to be one.
More info on ULF's as well as the version changes can be found here:
http://www.bimmernav.com/ulfchanges.html
ULF Version number History:
84216934552 end of life 06/03 1st generation
84216938610 end of life 10/03 2nd generation
84216934961 end of life 03/04 3rd generation
84216950089 end of life 06/04 4th generation
84216945387 end of life 01/05 5th generation
84106955522 end of life 10/05 6th generation
84106969268 end of life 04/06 7th generation
84216958358 end of life 05/06 8th generation
84106987546 end of life 09/06 9th generation
84106980130 end of life 11/06 10th generation
84109133329 end of life 01/07 11th generation
84109145007 end of life 05/07 12th generation
84109154358 current production 13th generation
Snappy
::34::
    • Сообщений 6383
    • Авто: Е46 M3///
up
    • Сообщений 6383
    • Авто: Е46 M3///
::butch::
Рекомендуем почитать на тему Продам блок ULF - Bluetooth - 2500р
  • Блок zke
    Доброго дня, товарищи! Помогите, пожалуйста, советом! Возникла проблема с центральным замком. Срабат...
  • ABS+ASC умер блок?
    Всем доброго времени суток! В общем ситуация следущая, на днях возвращался из дачи, все было хорошо,...
    • Сообщений 6383
    • Авто: Е46 M3///
    • Сообщений 6383
    • Авто: Е46 M3///
    • На форуме с 17 11 2014, 23:41
    • Сообщений 233
а как подключать ? схемы , проводка , по экзисту ещё антена нужна
    • Сообщений 6383
    • Авто: Е46 M3///
artamon :
Тут основная тема.
viewtopic.php?f=48&t=15440
Антенны если нет...нужно докупить.
    • Сообщений 6383
    • Авто: Е46 M3///
Я в свое время запарился искать ))) А сейчас что никому не нужно ? :( ::hp::
    • На форуме с 03 09 2014, 09:03
    • Сообщений 1141
    • Авто: 330Ci MT
Просто вторая версия, всем нужна 13ая
Visteon ULF Module end of life Oct-03 84216938610 2nd generation
My Coupe
    • Сообщений 1141
    • Авто: 330Ci MT
Если с новыми телефонами конектиться и работает то норм вариант ::kor::
My Coupe
У меня того же года блок. С ифон 7 работает без проблем.
    • Сообщений 1141
    • Авто: 330Ci MT
STR8 :
Это хорошо, а ты по году машины это понял или сам блок доставал? Их часто апгрейдили так что не факт что родной стоит ::kor::
My Coupe
Arthez :
STR8 :
Блок доставал конечно))
Кстаьи с 4с не ровно както работал - постоянно откл и вкл соединение по бт. При этом на мобиле точно рабочий бт
Так что ::37::
  • Блок zke
    • Сообщений 6383
    • Авто: Е46 M3///
STR8 :
    • Сообщений 6383
    • Авто: Е46 M3///
    • Сообщений 6383
    • Авто: Е46 M3///
:mad:
    • Сообщений 6383
    • Авто: Е46 M3///
Из-за Шевы продажи не идут по ходу ::stol::
RostoS :
:mad:
::37::
    • Сообщений 6383
    • Авто: Е46 M3///
STR8 :
RostoS :
:mad:
::37::
    • Сообщений 6383
    • Авто: Е46 M3///
    • Сообщений 6383
    • Авто: Е46 M3///
