/ Расшифруйте ошибки) на BMW
    • На форуме с 16 11 2011, 08:14
    • Сообщений 1131
    • Авто: Ведро, которое не перестаёт ломаться
    • Изображения: 66
Объясните популярнее, а то я чет немного не дружу и инпой. Вот текст ошибок:
4496 Rail-pressure plausibility
Error frequency : 2
Logistic counter: 40
Error occured 1. times at:
Engine speed 3496.50 1/min
fuel pre-supply pressure 2.48 bar
Einspritzmenge 57.35 mm^3
RPC rail pressure 777.11 bar
Fehler aufgetreten bei 272930.00 km
Error occured 2. times at:
Engine speed 1823.18 1/min
fuel pre-supply pressure 3.47 bar
Einspritzmenge 32.26 mm^3
RPC rail pressure 427.71 bar
Fehler aufgetreten bei 274720.00 km
Error present
Sporadic error
Control deviation over engine speed too great
Errorcode: 11 90 28 02 FC 20 8C 9B 70 81 6A 9D 20 49 D9 3F
47 6B 50 00 00 00 00 00 00
-------------------------------------------------------------2550 Rail pressure control at start
Error frequency : 14
Logistic counter: 33
Engine speed 224.78 1/min
fuel pre-supply pressure 1.76 bar
Einspritzmenge 25.09 mm^3
RPC rail pressure 66.27 bar
Engine speed 299.70 1/min
fuel pre-supply pressure 3.28 bar
Einspritzmenge 24.07 mm^3
RPC rail pressure 114.46 bar
Fehler aufgetreten bei 274290.00 km
Error occured 3. times at:
fuel pre-supply pressure 3.07 bar
Einspritzmenge 28.16 mm^3
RPC rail pressure 24.10 bar
Error not present
Sporadic error
Rail-pressure build up
Errorcode: 09 F6 21 0E F8 10 09 6E 31 0B 6A 9D 10 0C CD 2F
13 6B 25 10 09 C0 37 04 6B
-------------------------------------------------------------5651 Rough idle speed controller
Error frequency : 2
Logistic counter: 28
Engine speed 749.25 1/min
Coolant temperature 88.00 Grad C
Einspritzmenge 10.24 mm^3
Supply voltage 13.89 V
Coolant temperature 96.88 Grad C
Einspritzmenge 9.22 mm^3
Fehler aufgetreten bei 274680.00 km
Error not present
Sporadic error
correction amount to big
Errorcode: 16 13 1C 02 78 01 1E BD 14 78 6B 25 01 1E CA 12
78 6B 4C 00 00 00 00 00 00
Датчик колена наелся?
    • Сообщений 11635
    • Авто: 318i, N42, AT, седан
Дословный перевод
bumalik :
Error frequency : 2
нечитаемый сигнал датчика давления в рэйле
частота возникновения ошибки 2 раза
bumalik :
контроль давления в рэйле при старте
частота возникновения ошибки 14 раз
bumalik :
Error frequency : 2
контроль плавности холостого хода
частота повторения ошибки 2 раза
а уже специфику возникновения данных ошибок и их симптомов лучше подскажут местные дизелисты :)
    • Сообщений 1131
    • Изображения: 66
Спасибо.
    • Сообщений 11635
bumalik :
Спасибо.
не за что....кстати,вторая ошибка у тебя постоянная,т.е. присутствует всегда ,а две остальные периодические,т.е. то есть,то нет....скорее всего причину всех бед нужно искать от постоянной ошибки...
    • Сообщений 1131
    • Изображения: 66
Темуджин :
Тож так считаю
    • Сообщений 11635
bumalik :
Темуджин :
Тож так считаю
вот эта
проблема с давлением топлива в рейле....
    • Психотерапевт Клуба
    • Сообщений 50464
    • Авто: トヨタ自動車株式会社
датчик давления под замену
Рекомендуем почитать на тему Расшифруйте ошибки)
    • Сообщений 11635
Питерская Ракета :
скорее всего .....потому как эта ошибка появилась первой (судя по расшифровке и одометру на тот момент) ...в этот же момент в первый раз вылезли остальные ошибки ....
Серж,2,5 атмосферы для подкачивающего насоса мало же? А в рейле после ТНВД получается 777 атмосфер(из описания ошибки) ,так?
    • Сообщений 50464
    • Авто: トヨタ自動車株式会社
Темуджин :
Питерская Ракета :
нюансы не подскажу, но подкачивающий 7 бар давит
    • Сообщений 11635
Питерская Ракета :
Темуджин :
Питерская Ракета :
Тогда,если я правильно понял из описания ошибки,то во время первого появления ошибки давление после подкачивающего насоса было 2,48 бара, а во второй раз проявления ошибки давление там же уже 3,47 бара ....следовательно вполне мог умереть подкачивающий насос,не?
    • Сообщений 1131
    • Изображения: 66
Заменил уже фильтр и насос подкачивающий. Заодно нашел подливающую форсунку, но рабочую) И все равно не заводится мотор. Было ощущение, что один цилиндр не работает или работает не правильно. Потом при разгоне появилась вибрация. На холостых двиг работал как часы. Потом он просто заглох и не завелся.
Вихревые удалены, ес чё)
    • Сообщений 11635
bumalik :
а эти ошибки были до замены покачивающего насоса или после?
    • Сообщений 1131
    • Изображения: 66
Думаю, если бы клапан регулировки, то было бы это: "При появлении электрической неисправности в управлении клапаном регулировки давления в магистрали Rail в ЗУ записывается сообщение о неисправности 1195 ”Клапан регулировки давления в магистрали Rail”.
Последствие:
подаются сигналы управления с минимальной скважностью
ограничение количества."
    • Сообщений 1131
    • Изображения: 66
Темуджин :
bumalik :
До
    • Сообщений 1131
    • Изображения: 66
В общем вывод: Датчик давления выкинуть, запастись канистрой с бензином и спичками...так...на всякий случай.... ::xa:: ::xa::
    • Сообщений 11635
bumalik :
Погоди поджигать,главный дизелист уже читает тему ;)
    • Модератор Клуба
    • Модератор Клуба
    • Сообщений 4583
bumalik :
Истовый дизельеро берёт канистру с идеологически верной и духовно близкой соляркой ::butch::
Ракетоносец прав в части не мудрить с измерением сопротивлений датчика на рейле (в другой теме) - практика последнего полугода показывает, что он имеет свойство дохнуть банально от времени, которое не щадит никого. Причём не только на 46х, но уже и на 90х. Есть резон поменять его в любом случае.
Скорее всего, прав Ракета и в части того, что проблема с датчиком. Темуджин прав в плане детализации о первичных и вторичных ошибках.
    • Сообщений 1131
    • Изображения: 66
helg :
bumalik :
Устану поджигать ::44:: :sm:
helg :
В этой части текста я чет запутался)))
Заказываю датчик в общем и не шаманю)
    • Модератор Клуба
    • Модератор Клуба
    • Сообщений 4583
bumalik :
helg :
bumalik :
Тем ярче эмоции :)
bumalik :
helg :
::daa:: перед установкой проверь проводку(разъём) на него - дабы исключить КЗ.
    • Сообщений 1131
    • Изображения: 66
Оке! Спасибо за советы! Побежал покупать датчик))
    • Сообщений 1131
    • Изображения: 66
helg :
О! А его от ЭБУ надо наверное откинуть для этого?
    • Модератор Клуба
    • Модератор Клуба
    • Сообщений 4583
bumalik :
helg :
Нет, я о другом - проверить разъём и проводку, чтобы убедиться, что причиной смерти старого датчика стало не КЗ :) а то и новый сдохнет быстро.
    • Сообщений 1131
    • Изображения: 66
helg :
bumalik :
helg :
Я думаю инпа сказала бы, что там коза сидит.
    • Сообщений 1131
    • Изображения: 66
Не датчик...
    • Модератор Клуба
    • Модератор Клуба
    • Сообщений 4583
bumalik :
Не датчик...
Мотор М57 или М57N? Евро3 или Евро4?
