01 05 2017, 23:47
02 05 2017, 11:57
02 05 2017, 12:04
чем кстати улф от тцу отличается не вкурсе?
Филевский писал(а): А на 335 по твоему что?
02 05 2017, 12:11
STR8
Цитата: The simple answer is that if you just want basic Bluetooth functionality and don't care about Voice Recognition, then you can simply order the TCU. If you care about VR for the phone, then you can program the TCU.
If you care about an eject box / snap-in adapter or VR for Navigation, then the ULF is the way to go. ***** Comparison: TCU: (Telematic Control Unit) - Costs less than the ULF (circa $350 US) - TCU does not support eject box or pairing button. - Full Voice Control is not supported out-of-the box. Voice Recognition can be enabled via coding for the phone only, not navigation - TCU supports BMW Assist (US only, and if your car was equipped with it from factory) ULF: Universal Ladefreisprechelektronik (Universal Hands-Free System) - The ULF system for the e46 had 13 generations of revisions to it. Most US dealers only sell the first generation -552 unit. These older units have a ton of issues and won't pair with most modern phones. Anything 6th generation and newer is pretty good. The 6th generation unit will pair with an iPhone 4 for instance. ECS Tuning can special order these to the US, along with Bimmernav. - The ULF is more expensive than the TCU. Runs about $600-$700 for the ULF. - Out-of-the box, Voice Control is enabled for both the phone and Navigation if you have it (no coding necessary) - Visteon is the OEM for BMW of these units - The ULF requires either a pairing button (OEM ones have been discontinued, but you can make one fairly easily) or an eject box that has a pairing button built into it. The pairing button is only required for initial pairing of the phone. NOTE: The button on the steering wheel is NOT a pairing button, nor can it be wired to be one. More info on ULF's as well as the version changes can be found here: http://www.bimmernav.com/ulfchanges.html ULF Version number History: 84216934552 end of life 06/03 1st generation 84216938610 end of life 10/03 2nd generation 84216934961 end of life 03/04 3rd generation 84216950089 end of life 06/04 4th generation 84216945387 end of life 01/05 5th generation 84106955522 end of life 10/05 6th generation 84106969268 end of life 04/06 7th generation 84216958358 end of life 05/06 8th generation 84106987546 end of life 09/06 9th generation 84106980130 end of life 11/06 10th generation 84109133329 end of life 01/07 11th generation 84109145007 end of life 05/07 12th generation 84109154358 current production 13th generation |
02 05 2017, 12:20
Snappy
03 05 2017, 11:44
up
04 05 2017, 10:42
Рекомендуем почитать на тему Продам блок ULF - Bluetooth - 2500р
05 05 2017, 20:41
06 05 2017, 22:39
06 05 2017, 23:54
а как подключать ? схемы , проводка , по экзисту ещё антена нужна
07 05 2017, 00:09
artamon писал(а): а как подключать ? схемы , проводка , по экзисту ещё антена нужна Тут основная тема. viewtopic.php?f=48&t=15440 Антенны если нет...нужно докупить. |
08 05 2017, 11:00
Я в свое время запарился искать ))) А сейчас что никому не нужно ?
08 05 2017, 11:05
Просто вторая версия, всем нужна 13ая
Visteon ULF Module end of life Oct-03 84216938610 2nd generation ![]() |
08 05 2017, 11:07
Если с новыми телефонами конектиться и работает то норм вариант
08 05 2017, 11:32
У меня того же года блок. С ифон 7 работает без проблем.
08 05 2017, 12:23
STR8 писал(а): У меня того же года блок. С ифон 7 работает без проблем. Это хорошо, а ты по году машины это понял или сам блок доставал? Их часто апгрейдили так что не факт что родной стоит
08 05 2017, 12:30
Arthez писал(а): STR8 писал(а): У меня того же года блок. С ифон 7 работает без проблем. Это хорошо, а ты по году машины это понял или сам блок доставал? Их часто апгрейдили так что не факт что родной стоит ![]() Блок доставал конечно)) Кстаьи с 4с не ровно както работал - постоянно откл и вкл соединение по бт. При этом на мобиле точно рабочий бт Так что
08 05 2017, 13:22
10 05 2017, 19:05
11 05 2017, 20:47
12 05 2017, 14:33
Из-за Шевы продажи не идут по ходу
12 05 2017, 14:34
RostoS писал(а): :mad:
12 05 2017, 14:58
STR8 писал(а): RostoS писал(а): :mad: ![]() |
13 05 2017, 21:43
14 05 2017, 11:44
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 25 |
