    • На форуме с 18 08 2008, 11:41
    • Сообщений 146
    • Авто: 318i N42 sedan 02г.
    • Изображения: 21
Господа, что это все значит, и почему не заводится моя бричка???
Что сломалось, и много-ли рублевых ассигнаций нужно уплатить???
E R R O R M E M O R Y
Date: 09.01.2012 17:25:40
ECU: ME9K_NG4
JobStatus: OKAY
Variant: ME9K_NG4
RESULT: 7 error in error memory !
274E CDKMD - Misfire detection, Checksum failure
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 3350 km
Engine speed (nmot) 2880.00 /min
rel. air filling (rl) 45.75 %
Engine temperature (tmot) 3.75 degrees C
gas level (tfst) 80.00 l
2. Umweltsatz
Mileage 517360 km
Engine speed (nmot) 10200.00 /min
rel. air filling (rl) 191.25 %
Engine temperature (tmot) 143.25 degrees C
gas level (tfst) 255.00 l
Katschдdigende Aussetzer
Test conditions fulfilled
Error present now, but not yet stored (debouncing phase)
Error would cause a warning lamp to light up
Error code: 07 27 4E C1 01 00 00 01 4F 48 3D 45 50 CA 18 FF
FF FF FF FF FF FF FF FF
2743 CDKMD01 - Misfire detection cyl.3
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 3350 km
2. Umweltsatz
Mileage 517360 km
Error code: 07 27 43 C1 01 00 00 01 4F 48 3D 45 50 CA 18 FF
2745 CDKMD03 - Misfire detection cyl.2
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 3350 km
2. Umweltsatz
Mileage 517360 km
Error code: 07 27 45 C1 01 00 00 01 4F 48 3D 45 50 CA 18 FF
28D7 CDKDGENBS - Generator communication
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 5520 km
Supply voltage (ub) 6.22 V
Intake air temperature (tans) -48.00 degrees C
from generator rec. load signal(dffgen) 27.84 %
2. Umweltsatz
Mileage 166720 km
from generator rec. load signal(dffgen) 25.49 %
3. Umweltsatz
Mileage 164720 km
Supply voltage (ub) 24.02 V
Intake air temperature (tans) 143.25 degrees C
from generator rec. load signal(dffgen) 99.99 %
Kommunikationsverlust
Error not present now, but already stored
Error would not cause a warning lamp to light up
Error code: 07 28 D7 24 25 00 00 02 28 48 42 00 47 41 20 48
42 00 41 40 58 FF FF FF
278B CDKTM - Engine temperature
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 5520 km
engine temp. rep.value out of model (tmew) 6.00 Grd C
Intake air temperature (tans) 1.50 degrees C
Engine speed (nmot) 4120.00 /min
ADC TM (adtm) 1.27 V
2. Umweltsatz
Mileage 17460 km
3. Umweltsatz
Mileage 14900 km
engine temp. rep.value out of model (tmew) 143.25 Grd C
ADC TM (adtm) 5.00 V
Motortemperatursignal unplausibel gegenueber Modell
Error not occurred yet
Error code: 07 27 8B 08 01 00 00 02 28 48 42 67 41 06 D2 48
42 67 41 05 D2 FF FF FF
2862 CDKDVULV - VVT-Power supply
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 604560 km
Engine temperature (tmot) -43.50 degrees C
Ambient temperature (tumg) -3.75 Grd C
2. Umweltsatz
Mileage 264170 km
Engine temperature (tmot) -48.00 degrees C
Ambient temperature (tumg) 0.00 Grd C
3. Umweltsatz
Mileage 200170 km
Ambient temperature (tumg) -6.75 Grd C
Spannung zu niedrig
Error code: 07 28 62 82 05 00 00 EC 28 48 42 06 3B 67 31 48
42 00 40 4E 31 48 42 00
2865 CDKDVPMN - Power supply limit VVT-emergency
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 2960 km
Engine temperature (tmot) -39.75 degrees C
VVT-value in according of control(vvt_iw_u) 23.05 %
2. Umweltsatz
Mileage 266230 km
VVT-value in according of control(vvt_iw_u) 99.60 %
Exzenterwinkel faehrt nicht auf Vollhubposition
Error code: 07 28 65 82 05 00 00 01 28 48 42 0B 3B 67 FF FF
    • Сообщений 4148
    • Торговая репутация: +20
Es ist fantastisch!
    • На форуме с 25 07 2011, 15:24
    • Сообщений 507
    • Авто: 325xi E46, 2003
Хороший пробег.. и вообще очень интетересно в одном месте Mileage 517360 km, в другом чуть боле 200к...
Что ли 300к пробега ошибки не чистили ?
и темпеаатура двигателя -37 +) и -43, когда на улице +. "Engine temperature (tmot) -43.50 degrees C"
Последний раз редактировалось netdog 09 01 2012, 19:20, всего редактировалось 1 раз.
    • Сообщений 507
Я бы на твоём месте ошибки потёр и заного попытался завести ДВС, и смотреть че осталось =)
Обороты вон там в обдном месте 10к
точно подметил:
людоед :
Es ist fantastisch!
    • Тамбовский Волк
    • Сообщений 10631
    • Авто: E60 LCI 525xd
людоед :
Es ist fantastisch!
Скаа хорош я больше не могу
Рекомендуем почитать на тему Ошибки по INPA - was ist das???
Сейчас этот форум просматривают: Google [Bot] и гости: 27
