| Ошибки по INPA - was ist das??? https://www.e46club.ru/forumvb/viewtopic.php?f=16&t=66331 |
Страница 1 из 1 |
| Автор: | Alexnew [ 09 01 2012, 16:14 ] |
| Заголовок сообщения: | Ошибки по INPA - was ist das??? |
Господа, что это все значит, и почему не заводится моя бричка??? Что сломалось, и много-ли рублевых ассигнаций нужно уплатить??? E R R O R M E M O R Y --------------------------------------- Date: 09.01.2012 17:25:40 ECU: ME9K_NG4 JobStatus: OKAY Variant: ME9K_NG4 ------------------------------------------------------------- RESULT: 7 error in error memory ! ------------------------------------------------------------- 274E CDKMD - Misfire detection, Checksum failure Error counter: 0 Logistic counter: 0 1. Umweltsatz Mileage 3350 km Engine speed (nmot) 2880.00 /min rel. air filling (rl) 45.75 % Engine temperature (tmot) 3.75 degrees C gas level (tfst) 80.00 l 2. Umweltsatz Mileage 517360 km Engine speed (nmot) 10200.00 /min rel. air filling (rl) 191.25 % Engine temperature (tmot) 143.25 degrees C gas level (tfst) 255.00 l Katschдdigende Aussetzer Test conditions fulfilled Error present now, but not yet stored (debouncing phase) Error would cause a warning lamp to light up Error code: 07 27 4E C1 01 00 00 01 4F 48 3D 45 50 CA 18 FF FF FF FF FF FF FF FF FF ------------------------------------------------------------- 2743 CDKMD01 - Misfire detection cyl.3 Error counter: 0 Logistic counter: 0 1. Umweltsatz Mileage 3350 km Engine speed (nmot) 2880.00 /min rel. air filling (rl) 45.75 % Engine temperature (tmot) 3.75 degrees C gas level (tfst) 80.00 l 2. Umweltsatz Mileage 517360 km Engine speed (nmot) 10200.00 /min rel. air filling (rl) 191.25 % Engine temperature (tmot) 143.25 degrees C gas level (tfst) 255.00 l Katschдdigende Aussetzer Test conditions fulfilled Error present now, but not yet stored (debouncing phase) Error would cause a warning lamp to light up Error code: 07 27 43 C1 01 00 00 01 4F 48 3D 45 50 CA 18 FF FF FF FF FF FF FF FF FF ------------------------------------------------------------- 2745 CDKMD03 - Misfire detection cyl.2 Error counter: 0 Logistic counter: 0 1. Umweltsatz Mileage 3350 km Engine speed (nmot) 2880.00 /min rel. air filling (rl) 45.75 % Engine temperature (tmot) 3.75 degrees C gas level (tfst) 80.00 l 2. Umweltsatz Mileage 517360 km Engine speed (nmot) 10200.00 /min rel. air filling (rl) 191.25 % Engine temperature (tmot) 143.25 degrees C gas level (tfst) 255.00 l Katschдdigende Aussetzer Test conditions fulfilled Error present now, but not yet stored (debouncing phase) Error would cause a warning lamp to light up Error code: 07 27 45 C1 01 00 00 01 4F 48 3D 45 50 CA 18 FF FF FF FF FF FF FF FF FF ------------------------------------------------------------- 28D7 CDKDGENBS - Generator communication Error counter: 0 Logistic counter: 0 1. Umweltsatz Mileage 5520 km Engine speed (nmot) 2880.00 /min Supply voltage (ub) 6.22 V Intake air temperature (tans) -48.00 degrees C from generator rec. load signal(dffgen) 27.84 % 2. Umweltsatz Mileage 166720 km Engine speed (nmot) 2880.00 /min Supply voltage (ub) 6.22 V Intake air temperature (tans) -48.00 degrees C from generator rec. load signal(dffgen) 25.49 % 3. Umweltsatz Mileage 164720 km Engine speed (nmot) 10200.00 /min Supply voltage (ub) 24.02 V Intake air temperature (tans) 143.25 degrees C from generator rec. load signal(dffgen) 99.99 % Kommunikationsverlust Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Error code: 07 28 D7 24 25 00 00 02 28 48 42 00 47 41 20 48 42 00 41 40 58 FF FF FF ------------------------------------------------------------- 278B CDKTM - Engine temperature Error counter: 0 Logistic counter: 0 1. Umweltsatz Mileage 5520 km engine temp. rep.value out of model (tmew) 6.00 Grd C Intake air temperature (tans) 1.50 degrees C Engine speed (nmot) 4120.00 /min ADC TM (adtm) 1.27 V 2. Umweltsatz Mileage 17460 km engine temp. rep.value out of model (tmew) 6.00 Grd C Intake air temperature (tans) 1.50 degrees C Engine speed (nmot) 4120.00 /min ADC TM (adtm) 1.27 V 3. Umweltsatz Mileage 14900 km engine temp. rep.value out of model (tmew) 143.25 Grd C Intake air temperature (tans) 143.25 degrees C Engine speed (nmot) 10200.00 /min ADC TM (adtm) 5.00 V Motortemperatursignal unplausibel gegenueber Modell Test conditions fulfilled Error not occurred yet Error would not cause a warning lamp to light up Error code: 07 27 8B 08 01 00 00 02 28 48 42 67 41 06 D2 48 42 67 41 05 D2 FF FF FF ------------------------------------------------------------- 2862 CDKDVULV - VVT-Power supply Error counter: 0 Logistic counter: 0 1. Umweltsatz Mileage 604560 km Engine speed (nmot) 2880.00 /min Supply voltage (ub) 6.22 V Engine temperature (tmot) -43.50 degrees C Ambient temperature (tumg) -3.75 Grd C 2. Umweltsatz Mileage 264170 km Engine speed (nmot) 2880.00 /min Supply voltage (ub) 6.22 V Engine temperature (tmot) -48.00 degrees C Ambient temperature (tumg) 0.00 Grd C 3. Umweltsatz Mileage 200170 km Engine speed (nmot) 2880.00 /min Supply voltage (ub) 6.22 V Engine temperature (tmot) -48.00 degrees C Ambient temperature (tumg) -6.75 Grd C Spannung zu niedrig Test conditions fulfilled Error not occurred yet Error would cause a warning lamp to light up Error code: 07 28 62 82 05 00 00 EC 28 48 42 06 3B 67 31 48 42 00 40 4E 31 48 42 00 ------------------------------------------------------------- 2865 CDKDVPMN - Power supply limit VVT-emergency Error counter: 0 Logistic counter: 0 1. Umweltsatz Mileage 2960 km Engine speed (nmot) 2880.00 /min Supply voltage (ub) 6.22 V Engine temperature (tmot) -39.75 degrees C VVT-value in according of control(vvt_iw_u) 23.05 % 2. Umweltsatz Mileage 266230 km Engine speed (nmot) 10200.00 /min Supply voltage (ub) 24.02 V Engine temperature (tmot) 143.25 degrees C VVT-value in according of control(vvt_iw_u) 99.60 % Exzenterwinkel faehrt nicht auf Vollhubposition Test conditions fulfilled Error not occurred yet Error would cause a warning lamp to light up Error code: 07 28 65 82 05 00 00 01 28 48 42 0B 3B 67 FF FF FF FF FF FF FF FF FF FF ============================================================= |
| Автор: | Ferrum [ 09 01 2012, 17:34 ] |
| Заголовок сообщения: | Re: Ошибки по INPA - was ist das??? |
Es ist fantastisch! |
| Автор: | netdog [ 09 01 2012, 19:16 ] |
Хороший пробег.. и вообще очень интетересно в одном месте Mileage 517360 km, в другом чуть боле 200к... Что ли 300к пробега ошибки не чистили ? и темпеаатура двигателя -37 +) и -43, когда на улице +. "Engine temperature (tmot) -43.50 degrees C" |
| Автор: | netdog [ 09 01 2012, 19:19 ] |
Я бы на твоём месте ошибки потёр и заного попытался завести ДВС, и смотреть че осталось =) Обороты вон там в обдном месте 10к точно подметил: людоед : Es ist fantastisch!
| Автор: | Zeke [ 09 01 2012, 19:42 ] |
людоед : Es ist fantastisch! Скаа хорош я больше не могу |
