/ U4GM Guide to Monopoly Go Sprout Science Event Rewards на BMW
    • На форуме с 10 08 2026, 10:45
    • Сообщений 4
Monopoly Go Racer Event players have another short milestone event to tackle as Sprout Science arrives in Monopoly GO. The event starts on August 12 and gives Tycoons a limited window to collect points, reach milestones, and pick up useful rewards. With the event running for less than two days, getting started early is the safest way to avoid a last-minute scramble.
Sprout Science Event Schedule
According to current event listings, Sprout Science is scheduled to run from August 12 at 1:00 PM until August 14 at 9:59 AM. Event times can sometimes appear differently depending on your region or account, so checking the event panel in-game is still the best way to confirm the exact countdown.
This is a standard milestone event rather than a leaderboard competition. Your progress is based on the number of event points you earn while moving around the Monopoly GO board.
How to Earn Sprout Science Points
The basic strategy is straightforward:
• Roll the dice and move around the board.
• Land on the designated scoring spaces.
• Collect event points from successful landings.
• Reach each milestone to claim its reward.
• Continue playing if you want to push toward the higher tiers.
The plant-and-science theme gives the event a different look, but the gameplay should feel familiar to regular players. Rewards can include dice rolls, cash, sticker packs, boosts, and other items that help with ongoing activities.
Make Your Dice Count
One of the easiest mistakes is using a large dice multiplier without checking what is coming up on the board. Before rolling, take a moment to look at your current position and the locations of valuable spaces.
If a scoring space is several rolls away, a smaller multiplier can help conserve dice. On the other hand, when several useful spaces are grouped within a favorable distance, a higher multiplier can turn a good landing into a much larger point gain.
Players who are also following buy Monopoly Go Racer Event related content should also keep an eye on their overall dice economy. Spending everything on one milestone event can make it harder to participate in tournaments and other limited-time activities that appear alongside it.
Take Advantage of Other Activities
Railroad spaces deserve extra attention. If a Railroad landing triggers a Shutdown or Bank Heist while a tournament is active, one roll can contribute toward several objectives at the same time.
It is also worth completing other easy daily activities, including:
• Daily Quick Wins
• Free Shop gifts
• Tournament milestones
• Active banner events
• Sticker and album-related tasks
These activities can provide additional dice or other resources, allowing you to keep rolling without burning through your entire reserve.
Should You Chase Every Milestone?
That depends on your dice supply. Casual players should focus on the early rewards and stop when the cost of reaching the next milestone no longer feels worthwhile. Players with a healthy dice balance can push further, especially when the rewards include valuable dice, sticker packs, or resources needed for another active event.
Because Sprout Science has a short schedule, starting early also gives you more flexibility. You can see how quickly your points are building before deciding whether to spend more dice.
Final Tips
Sprout Science is a relatively simple event, but good timing can make a noticeable difference. Watch the board, choose multipliers carefully, collect free resources, and avoid wasting dice on low-value rolls.
If you're also researching Monopoly Go Racer Event buy options and other current Monopoly GO activities, keep your resources balanced rather than focusing on a single event. Sprout Science may only last a short time, but with a sensible dice strategy, it can be an easy way to add extra rewards to your account.
Рекомендуем почитать на тему U4GM Guide to Monopoly Go Sprout Science Event Rewards
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 106
